overcharging battery?
305rider
Post by 305rider » Sun Aug 28, 2016 10:38 am
I have a Striker Trail tech digital speed/voltage display unit on my 1965 CL77 305 Scrambler. While riding the voltage is reading around 16 volts. Any concerns about destroying the battery or is it more likely the trail tech reading is not accurate?
Re: overcharging battery?
Post by LOUD MOUSE » Sun Aug 28, 2016 11:54 am
As a rule you will boil the battery dry.
What type battery are you using. .....................lm
305rider wrote:I have a Striker Trail tech digital speed/voltage display unit on my 1965 CL77 305 Scrambler. While riding the voltage is reading around 16 volts. Any concerns about destroying the battery or is it more likely the trail tech reading is not accurate?
305rider
Overcharging battery
Post by 305rider » Sun Aug 28, 2016 7:30 pm
Yuasa battery
Re: Overcharging battery
Post by LOUD MOUSE » Sun Aug 28, 2016 7:44 pm
If you charge at that rate and ride much you will boil that battery dry and ruin it same as we did in the 60's until HONDA lowered the magnetism of the rotor. ......................lm
305rider wrote:Yuasa battery
revlover
Post by revlover » Sun Aug 28, 2016 10:07 pm
If you have doubts about the trail tech, check it against another more trusted meter. If 16 volts is correct, a voltage regulator might be a good idea if you plan to ride at highway speed for extended periods. There are a number of aftermarket units available and also posts here that detail adapting a very reasonably priced Kohler rectifier/regulator unit.
