New member with '66 CL77
OldScrambler
Post by OldScrambler » Tue Jan 31, 2017 11:47 am
If you know you are going to use the new screws over a LONG period of time...........you could make them fit by running an ISO tap into the tabs on the tank. I placed a small block of wood behind the tab to protect the tank. Your moving a small amount of metal by a very small margin...........but do it carefully and at heated room-temperature. I have successfully accomplished this task on the tank as well as on the speedo-mount to the headlight bucket.
Glenn-N
Post by Glenn-N » Fri Feb 03, 2017 10:27 am
OldScrambler wrote:If you know you are going to use the new screws over a LONG period of time...........you could make them fit by running an ISO tap into the tabs on the tank. I placed a small block of wood behind the tab to protect the tank. Your moving a small amount of metal by a very small margin...........but do it carefully and at heated room-temperature. I have successfully accomplished this task on the tank as well as on the speedo-mount to the headlight bucket.
Good idea. Will keep it in mind.
Glenn-N
Post by Glenn-N » Fri Feb 03, 2017 11:17 am
What'd be the correct chain guard for my CL? With our without louvres?
Frame nr. 10293xx
Post by LOUD MOUSE » Fri Feb 03, 2017 11:19 am
Without louvers. ..................lm
Glenn-N wrote:What'd be the correct chain guard for my CL? With our without louvres?
Frame nr. 10293xx
Glenn-N
Post by Glenn-N » Fri Feb 10, 2017 2:24 pm
Thanks Ed.
Is it normal for the headlightrim to fit supertight on the headlight case?
Really difficult to get it on properly.
Post by LOUD MOUSE » Fri Feb 10, 2017 4:52 pm
Most of them I use the palm of my hand and smack it. ..................lm
Glenn-N wrote:Thanks Ed.
Glenn-N
Post by Glenn-N » Thu Feb 16, 2017 12:23 pm
Are these the period-correct plug caps I'd need?
