Post
by LOUD MOUSE » Sun Jul 09, 2017 7:20 am
Fix the leak with a coil rather than over size the bolt.
That is a nice bike you have now. ....................lm
Glenn-N wrote:Drove it for the first time yesterday.
Well... This just exceeds my expectations. The sound is just nuts when you open the throttle in 3rd or 4th gear.
Front fork is leaking but I'm planning to rebuilt it in the near future of next winter.
Special thanks to Ed, Tim etc. for the advice and parts.
Muddy
Post
by Muddy » Mon Jul 10, 2017 4:12 am
Glenn-N wrote:Took some pictures.
Wow - that is special, great job.
Thanks.
Regards
Muddy
'64 C72
'63 C72
HondaPaul
Post
by HondaPaul » Sun Jul 16, 2017 11:43 am
Very nice job Glenn!
Glenn-N
Post
by Glenn-N » Sun Jul 30, 2017 1:52 pm
Over tightened the fuel inlet screw on my left carb, ruined the thread...
Guess it's not possible to repair this, so anyone with a spare set of carbs for sale?
Glenn-N
Post
by Glenn-N » Fri Aug 04, 2017 12:34 pm
Will be rebuilding my front fork this weekend.
What's the best way to reinstall the front fender brace without messing up fresh paint? When the forks are already mounted on the inner tubes or is it possible to mount the fender brace to both outer fork tubes and then slide them over the inner tubes together?
edit:
Noted the order for the clips on the inner tube but forgot which way the chamfered ring should go on? Chamfer side up or down?
Thanks.
Glenn-N
Post
by Glenn-N » Sat Aug 26, 2017 3:16 pm
All good, she's back on the road with a rebuilt front fork.
Carbs issues also solved.
Just one thing, when the engine is really warm and I stop at a stoplight it idles at a rather high rpm.
Adjusting the slide screw doesn't seem to make a lot of difference.
Do I need to adjust the air screw? I have them set at 1+1/4 turn out.
Post
by LOUD MOUSE » Sat Aug 26, 2017 3:27 pm
The slides are not synced together.
One side is high and drives the idle. ........................lm
Glenn-N wrote:All good, she's back on the road with a rebuilt front fork.
