Seadog wrote:How about using a little bit of paint stripper?
Literature for CA77 Restore
- Jims65CA77
Have a look at this post to find the serial number. Look at the bottom of the spring on the brake light. Mine is just behind that. They are hard to find. See this older post where I added photos.
http://www.honda305.com/forums/cannot-f ... 33515.html
Jim
You may want to check the example by casamere. ..............lm
rrietman wrote:certainly the stampings on the headstocks were machine done, but I have seen some early dreams with numbers crooked, spacing off, and only lightly pressed. talking with other dream guys, we conclude that some of the dreams must have been hand stamped. but , no. I am not sure.
Thanks
Randy
Back in the dark ages, if a CA sustained frame/rear fender damage, it was easier for the dealer to replace the frame, rather than repair the damage. The replacement frames from Honda did not have a serial number stamped on them, the dealer did that while scrapping out the unhappy piece. Factory stamping should be nice, the dealer's, not very. Regards, Chase
