Resurrection of a wreck
John
Give me a couple of days to sort out what I have. G
G,
Honda started the 7 digit VIN sequence in 1965. What am I missing that would possibly make this a 1964? HT
Tom
Just going off the chart in the front of the parts manual. See earlier in this thread. G
Today, I started stripping the engine, the cam chain roller ran very roughly so that's to be added to my list of spares required. The cam chain had to be cut in order to remove the head because, of course the split link was at the bottom of the engine, once off, the root of the problem was revealed:
![]() The piston was freed off without too much drama, it wasn't seized too badly and a short soak in paraffin followed by a couple of taps with a wooden drift soon got it moving. When the barrel was removed, there didn't appear to be any damage to the bores, I'll hone them soon to verify their condition: ![]() A closer look at the pistons revealed a chunk missing from from the LH side, I had noticed while dismantling the motor that there were a few marks on a couple of the mating faces where levers, possibly screwdrivers had been jammed in to part components, and these, together with the state of the piston have convinced me that the whole thing needs to be completely stripped down: ![]() Before I finished for the afternoon, I started to remove the clutch cover, most of the pan head screws were butchered and tightened far too tightly, tight enough that I shattered a driver bit whilst attempting to remove one with my 35 year old impact screwdriver. I completed the afternoons work by drilling the heads off all but two of the screws.
