All Balls needle bearings, what spacer do I use?
I have a 67 scrambler. I bought the all balls needle bearing set and it says to measure the existing bearing stack to determine if you need to use the thin or thick spacer on the bottom. I don't have the original bearings that came off the bike, the bike was disassembled years ago and is just going back together now. Is there another way to determine which one to use?
Brian
Brian
Bottom Bearing
You have't driven the lower outer race far enough into the frame. Looks to be about 3 - 5mm short of where it should be. Use a soft, aluminium, copper or brass drift and work your way round the bearing, keep going until it won't go in any further. You'll know when it's right as the noise will change.
