If I used your cams and other internal parts I would need $230. 00.
Let me know if I can help. ........................lm
Seadog wrote:Thanks, LM. That's a good idea. Before I saw your post, I sat for awhile thinking about it and came up with a slightly different method. I just treated the pin like a bushing. I have ¼" rod, washers, nuts and I cut a piece of conduit I had lying around and simply pushed the pin out. I lubed it as it moved and it gave no resistance. On the last bit, I attached a vice-grip and lightly tapped it with a hammer to completely remove the pin. Job done.
I'm not sure about what's next. I have to decide what I'm going to do about the top crankcase - replace it or try to repair it. There are pros and cons for both options. The same for the head. I broke fins dropping it. I have to decide whether I want to try an aluminum braze repair or just replace it. I just don't think that I can get it hot enough for a successful brazing repair, but then I can't seem to find a good replacement. More for me to think about. Until I make a decision, I can be cleaning, fixing and/or ordering parts.
