Dismantling CB77 forks - aluminium
GregMcN
Post by GregMcN » Mon Aug 27, 2018 2:58 pm
I wanted to check out the front forks on my CB77 project which has the later model aluminium forks. please can someone advise on how do you remove the chrome seal holders on these forks?
Are they a screw fitting like the earlier ones?
Greg
Re: Dismantling CB77 forks - aluminium
Post by LOUD MOUSE » Tue Aug 28, 2018 7:42 am
They slide/slip onto the top of the slider.
No threads or clips.
I carefully using soft material tap on the thin edge to remove them.
Sometimes they get damaged. .................lm
GregMcN wrote:I wanted to check out the front forks on my CB77 project which has the later model aluminium forks. please can someone advise on how do you remove the chrome seal holders on these forks?
Greg
GregMcN
Post by GregMcN » Wed Aug 29, 2018 2:26 pm
Thanks LM, I only had a diagram for the older forks.
Post by LOUD MOUSE » Wed Aug 29, 2018 5:13 pm
Actually HONDA doesn't show much on that. ..................lm
GregMcN wrote:Thanks LM, I only had a diagram for the older forks.
GregMcN
Post by GregMcN » Tue Sep 11, 2018 5:07 am
After quite a lot of effort I have managed to remove the sleeves though one has suffered some slight damage.
Next questions, what is the best way to remove the seals?
I also wondered if the insert inside the chrome sleeve can be removed / pushed out or is it fixed in some way? The reason being is that if I could turn the sleeve upside down the slight damage would not be visible?
Greg
Post by G-Man » Tue Sep 11, 2018 7:59 am
Greg
Pretty sure the inside piece is spot-welded in place.
GregMcN wrote:After quite a lot of effort I have managed to remove the sleeves though one has suffered some slight damage.
Greg
Post by LOUD MOUSE » Tue Sep 11, 2018 8:07 am
It is permanently fastened for sure. .......................lm
G-Man wrote:Greg
Greg
