Where did you connect the tester leads? Voltage numbers with one tester lead connected to ground don't mean much. Connect one test lead to the brown wire and the other one to pink or yellow.sarals wrote:Here's the results of the test.
Brown wire, 4000 RPM - 6.01 volts
Yellow wire, 4000 RPM - 6.00 volts
Pink wire, 4000 RPM - 6.01 volts
Low. Something is apparently wrong with the stator coil. Or, the magnets are weak in the rotor. Either is not good.
The Podtronics apparently works fine.
My CB77 No Longer Charges the Battery
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
- sarals
Mike, that's how I did it. That's only way to check an AC circuit, you're can't reference ground and get an accurate reading.mike in idaho wrote:Where did you connect the tester leads? Voltage numbers with one tester lead connected to ground don't mean much. Connect one test lead to the brown wire and the other one to pink or yellow.sarals wrote:Here's the results of the test.
Gentleman, thanks for the input!
48, I hear you. Absolutely.
Vince, Mike's still has one listed on Amazon. There's a NOS on eBay for the same price, too. Decisions.
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
1989 NT650 Hawk GT
Don't know if these guys might be able to help, but maybe they can do permanent magnets: http://www.scooterwest.com/item_details ... izing/4045
Let us know what you find out!
- sarals
Vince, I just sent them an email. Thank you for that!Vince Lupo wrote:Don't know if these guys might be able to help, but maybe they can do permanent magnets: http://www.scooterwest.com/item_details ... izing/4045
1989 NT650 Hawk GT
1989 NT650 Hawk GT
I'm with Mike on this one. I do not understand the following.
Can you describe the measurement points you measure between?
I'd suggest the following.
1. Measure DC battery voltage across its terminals with engine OFF
2. Measure DC battery voltage across its terminals with engine at idle
3. Measure DC battery voltage across its terminals with engine at 4000 RPM
The important things are not the absolute values, but whether the voltage goes up when revved. The level it goes to will depend on battery condition and its state of charge.
If there is no Voltage increase above what was measured in steps 1 and 2 when revved, then it's time to look in to the alternator. In my 48 years of Honda experience, alternator failure is rare. In fact, I have never seen it. I have seen bullet connectors on the pink wire with a bad connection, so it charged with lights off but discharged when the lights are on.
I guess the next steps would be. (Someone else may have a better set of tests.)
4. Disconnect the pink, yellow, and brown wires from the alternator and measure AC voltage from brown to yellow at a few thousand RPM, probably could do the same at idle.
5. Repeat 4. between brown and pink.
Only if 4 and 5 show AC results below 12 V would I suspect the alternator. If 4 and 5 show AC results above 12 V (remember the AC reading is an RMS value, so peak values are 1.4 times greater) or so, I'd suspect bad connections or the "podtronics" thingie.
If you could post them, I'd love to see the values you get for those 5 measurements.
Cheers,
Larry - Pasadena (not an expert, but have done all repairs on my CB77s since 1966)
Cheers,
