Trans Prob Solved -Shift drum bracket installed upside down
R100
Post by R100 » Wed Aug 12, 2015 6:42 pm
oldbikedude wrote:Yes you did. Now I'm waiting on new locking washers for the fork pins to arrive in the mail. & figure out what removes fresh "Honda bond4" off the cases.
Perhaps Permatex gasket remover.
Works for me. Although it wasn't Hondabond.
oldbikedude
Post by oldbikedude » Wed Aug 12, 2015 8:35 pm
Thanks R100.
'67 Ca77 Dream
sdaigle240
Post by sdaigle240 » Mon Sep 28, 2015 11:45 am
I got it all back together checking shift functionality along the way. it works fine UNTIL i put the side cover on. the shift shaft has been snapped and rewelded by the previous owner. it is not concentric (by atleast .040", ~1mm) and i suspect that as it rotates it binds into the case hole its meant to spin in. I bought another assembly on ebay and will try that.
makes me wonder what the heck they did to this bike while that bracket was on upside down. i suspect someone rode it anyway just jamming away at the shifter. Im hoping nothing else is badly worn as well. the pins on the drum didnt look bad but i havent a clue what new looks like either.
Steve
CA78 65?
CB77 65?
sdaigle240
Post by sdaigle240 » Mon Oct 05, 2015 10:23 am
new shift shaft worked.
Steve
CA78 65?
CB77 65?
deafanddiabetic
Post by deafanddiabetic » Mon Oct 05, 2015 11:28 am
Well, that ruined my day.
Last edited by deafanddiabetic on Mon Oct 05, 2015 12:30 pm, edited 1 time in total.
1964 CA72
1974 BMW R75/6
1969 CL450
deafanddiabetic
Post by deafanddiabetic » Mon Oct 05, 2015 11:45 am
No other way to get it in without taking it all apart again, huh?
Man. I want to break things right now.
I followed fiches, took pictures before tear down to follow when I put it together again. In fact, I remember that I couldn't get the retainer in the other way so it "made sense" that it fit on the bottom side.
tu90 iolremniolvaermiopefqmigpo ewmiop rmipog wemipgo wrm9gcipow45gm 90[eiposdnb;okfcbn89pigjq89-t4q3j89gpiergnioegrn k;ersbmiposr;bje9r0[igow45j890[igow45mio;ger jkva k;lerigoeqj89-tq34ht0834niog;ernigo;gnio;kearkla,ar89-ewpcjrm89-24pq4j gpq
1964 CA72
1974 BMW R75/6
1969 CL450
sdaigle240
Post by sdaigle240 » Tue Oct 06, 2015 8:13 am
If i i had to correct the issue again i would drain the bike and flip the thing over rather than pull the motor. it really wasnt that bad but it is a bummer.
Steve
CA78 65?
CB77 65?
