Super Slow 65 CB77 Restoration commences
jugger18
Post by jugger18 » Sat Nov 29, 2014 4:56 pm
Well I just carried the engine to the basement :) That was fun...said no one ever. I have to deal with stuck/frozen screws on the clutch cover
Waveblaster
Post by Waveblaster » Sat Nov 29, 2014 8:10 pm
impact driver for the tricky ones.
jugger18
Post by jugger18 » Sat Nov 29, 2014 8:19 pm
Yeah. I bought one but have not had much luck with it so far. It was a cheap one from harbor freight
ahenthus
Post by ahenthus » Sat Nov 29, 2014 9:41 pm
The HF impact you're using probably has Phillips bits. You need to buy a JIS bit set. JIS will fit the fasteners properly and you should get much better purchase whereas the SAE bits you're using cannot make full contact with the fasteners because they're designed to cam out. JIS bits are readily available.
Post by LOUD MOUSE » Sun Nov 30, 2014 7:39 am
Where can I get JIS bits for a Hammer Drive?. .......lm
ahenthus wrote:The HF impact you're using probably has Phillips bits. You need to buy a JIS bit set. JIS will fit the fasteners properly and you should get much better purchase whereas the SAE bits you're using cannot make full contact with the fasteners because they're designed to cam out. JIS bits are readily available.
R100
Post by R100 » Sun Nov 30, 2014 9:00 am
http://www.vesseltools.com/hand-tools/s ... ducts.html
LOUD MOUSE wrote:Where can I get JIS bits for a Hammer Drive?. .......lm
Post by LOUD MOUSE » Sun Nov 30, 2014 9:49 am
Thanks.
I ordered the 2400 set. ......lm
R100 wrote:http://www.vesseltools.com/hand-tools/s ... ducts.html
