rbaselt wrote:Congratulations, Dave. Brake shoes rarely need replacing in my experience unless the mileage is very high. But you can do an adjustment. On the front wheel, there are adjustments that begin with the brake linkage on the brake plate and continue with the brake cable mounting points both on the wheel and the handlebar control lever. It's important to get the sequence correct, so follow the procedure in the service manual. Check first that the dots on the two links on the brake plate are correctly aligned with the dots on the ends of the brake shoe cams. --Randall
help with timing chain and valve adjustment ??
DO "ALL" BRAKE ADJUSTMENTS WITH THE CABLES. ..........lm
