How do you disassemble the horn?
Post by LOUD MOUSE » Fri Feb 26, 2010 11:13 am
Ya do want a good lens gasket but the one at the mount is a small apx. 3/8" round one with a slot for the 2 wires to pass through. ...........lm
big-b wrote:That might be the best way to do it. I do want to replace the grommet where the wires come through, it's all dried out and i expect water will get in there.
Brian
cknight
Post by cknight » Fri Feb 26, 2010 12:36 pm
For the rectangular "grommet" on the horn dome that the two wires pass through, I've carved my own from a chunk of rubber (usually a section from an old automotive suspension bushing), Yes, the color is not the stock grey, but it keeps the contaminants out. This would really be a great item for someone to repro, but that's probably been hindered by no one being able to furnish a good sample, as they seem to decompose more than any other item on these bikes. If you do disassemble the horn, there is a thin gasket between the horn mechanism and the housing that does seem to help the volume, so try to preserve it. Regards, Chase
Post by G-Man » Fri Feb 26, 2010 5:35 pm
If you look where the domed cover meets the horn body you will see several dimples in the cover. At the joint face below the dimple there is a very slim slot. Push a thin flat screwdriver in the slot and you can pop the cover right off.
Innards look good
Innards look good
Domed cover wil pop off
Slot next to dimple is where to insert small screwdriver to prise off cover.
big-b
Post by big-b » Sat Feb 27, 2010 8:06 pm
Got it guys. Thanks for the help.
Brian
