3rd gear bindingSeems to be the case, with further exploration, that the problem is not there if I spin the gears a good 10 times, or so, before I switch gears. Which makes sense, since you don't normally switch rapidly from one gear to the next with out the gear set spinning a few hundred times in between, at least...
ca77 gearboxLooks good to me mate. It will be spinning a whole lot faster than you can turn it. The gear selection should not be a problem.
Brian.
