'67 Hawk Elctrical Gremlins, i.e. what am I looking at here?
Post by LOUD MOUSE » Sat Sep 08, 2012 8:03 pm
It starts inside the cover with the alignment of the gear marks and the spring then on outside the lever must be installed/aligned with the punch marks and as you place the cover on the engine you must align the "O" then install the cover.
SIMPLE !
Well when you get it right you will not forget how to do it. ......lmk
dagersh wrote:Thanks Man!
Not the place for it - but any quick link on how to align the Kick Starter, i.e the dot's and "o's" on the gears?
Suffering from a limp K/S arm and Viagara ain't helping! :)
Gersh
dagersh
Post by dagersh » Sat Sep 08, 2012 8:10 pm
Just to make sure -
The spring should look llike an "S" looking at the installation?
The "O"s should be aligned or do I load up tension and align the punches?
I caught your posts on the spring direction.
Also, how coiled should the spring be? I have one that is pretty tight and one that is, well, significantly loose. The loose one cam off my original cover that shattered at the K/S Bushing...
Thanks LM!
Gersh
dagersh
Post by dagersh » Sat Sep 08, 2012 8:14 pm
LM,
Searching as we are speaking - I think I forgot to turn the transmission gear all the way clockwise before installing the cover....
Gersh
Post by LOUD MOUSE » Sun Sep 09, 2012 2:15 am
There ya go. ..................lm
dagersh wrote:LM,
Gersh
dagersh
Post by dagersh » Sun Sep 09, 2012 3:09 pm
Thanks LM!
Now back to our regularly scheduled Elctrical Topics!!!
Gersh
Post by davomoto » Mon Sep 10, 2012 8:53 am
The part in your last pic appears to an electronic ignition control module. Have you removed the points cover to see what behind it?
Davo
dagersh
Post by dagersh » Mon Sep 10, 2012 10:35 am
Davo,
I will check that out. As I was looking at the wires coming out of the box, I traced them up to the points, but ran out of time.
I am going to pull the harness next weekend and record where these wires are hooked into. I will update as I go.
Thanks for the response!
Gersh
cron
