Hello and request for help.
Al Urquhar
Post by Al Urquhar » Fri Aug 07, 2015 11:19 am
No chance of any 'purchase' I'm afraid as the screw head is completely Donald Ducked. The only way forward would be to drill the head off, which I hope to avoid, so my fingers are now crossed that a replacement gasket will do the trick. Time will tell.
Post by G-Man » Fri Aug 07, 2015 1:34 pm
Al
If you are still in trouble, I can help out. I am a 'dab hand' at removing un-removable screws and, if all else fails, I have spare tachometer drives.
Al Urquhar wrote:No chance of any 'purchase' I'm afraid as the screw head is completely Donald Ducked. The only way forward would be to drill the head off, which I hope to avoid, so my fingers are now crossed that a replacement gasket will do the trick. Time will tell.
Al Urquhar
Post by Al Urquhar » Fri Aug 07, 2015 2:26 pm
Many thanks G. As I say, I'm hoping that the leak proves to be as a result of the lack of a decent gasket, so once I've fitted a replacement I'll be better able to decide whether or not I need to remove the cable attachment plate. If it does need removing I'll get back to you for a bit of expert guidance. Meanwhile, hope springs eternal, as they say.
mcconnellfrance
Post by mcconnellfrance » Fri Aug 07, 2015 3:03 pm
Reading your posts Al with great interest as I gave posted elsewhere on a leak from my tachometer drive. I think in my case, reading 48lesco, the rubber washer in the cable is missing. Anyone have a picture of it? I will try to make one once I know what it looks like. Thanks.
Gordon
Al Urquhar
Post by Al Urquhar » Fri Aug 07, 2015 4:00 pm
Having looked at the seal in the cable on my bike I can't see how it could be left out or, indeed, replaced as it's an integral part of the cable manufacture. I've taken a photo of mine but the system won't allow me to attach it to this posting.
48lesco
Post by 48lesco » Sat Aug 08, 2015 7:21 am
Here's an ebay ad with a pic of that end:
http://www.ebay.com/itm/NOS-Honda-SUPER ... 0869143291
mcconnellfrance
Post by mcconnellfrance » Sun Aug 09, 2015 1:13 pm
I have had a look at the cable on my CB77 and I see there is a small red sealing washer on the cable inner. See photo below.
https://www.flickr.com/photos/131927779 ... res/q969j2
I think my leak was coming from the interface between the knurled nut and the tacho drive bearing. I have fitted a thin fibre washer between the interface and it seems to have sured the leak on a 30 mile ride today.
https://www.flickr.com/photos/131927779 ... res/EBj0N8
Perhaps not the origial configuration but it does seem to have done the job to fix the oil leak.
Thanks to Al and 48lesco for your good advice.
