valve adjustment, breathers?
MUTT
Post by MUTT » Sat May 29, 2004 4:44 pm
After pawing thru a factory manual & another Superhawk book, ill be damned if I can find the valve lash- cb77. AND, like the other fellow- are thgose two stubs under the inlet ports the crankcase breathers, and indeed there is no, um, "balance tube" betyween the carbs ....Mutt
georGe
Re: valve adjustment, breathers?
Post by georGe » Thu Jun 03, 2004 9:53 pm
Valve lash should be seta .004inch intake &amp; exhaust.<br />No there is not a &quot;balance tube&quot; on the PW-26mm carbs<br />georGe
