Clicking noise in motor-CA77E
redlinerob
Post by redlinerob » Mon Feb 19, 2007 3:58 pm
I am currently rebuilding the top end and now that I have the top end disassembled when I turn the crankshaft clockwise, there is a clicking noise coming from inside the lower cases (I think in the transmission area). Obvisouly the oil is drained with both side cases removed and everything seems to be in order. The noise sounds uniform but I am not sure if this is normal or the cases need to be split to investigate. I have never heard this on other motor rebuilds, but I must admit this is my first rebuild on a vintage motor. Any knowledge before splitting the cases would be appreciated.
Re: Clicking noise in motor-CA77E
Post by LOUD MOUSE » Mon Feb 19, 2007 6:38 pm
Remove the lrft side cover and take a good look in there.
Then remove the (clutch parts) all of them and tur the Main Shaft of the trans.
Let us knw what ys have then. ................lm
redlinerob wrote:I am currently rebuilding the top end and now that I have the top end disassembled when I turn the crankshaft clockwise, there is a clicking noise coming from inside the lower cases (I think in the transmission area). Obvisouly the oil is drained with both side cases removed and everything seems to be in order. The noise sounds uniform but I am not sure if this is normal or the cases need to be split to investigate. I have never heard this on other motor rebuilds, but I must admit this is my first rebuild on a vintage motor. Any knowledge before splitting the cases would be appreciated.
fastjoe
clicking noise
Post by fastjoe » Mon Feb 19, 2007 8:31 pm
turn the kick shaft all the way clockwise. did the noise stop ?
Joe
Hahnda
Post by Hahnda » Mon Feb 19, 2007 9:48 pm
I heard the same click when I was rebuilding. Do as Joe says and it will probably go away, mine did.
redlinerob
Post by redlinerob » Tue Feb 20, 2007 6:51 pm
Thank you gentlemen, its funny the kickstarter wasn't even a thought, although it should have been! Thanks again, you saved alot of time and trouble.
