Throttle handle feels stuck, how do I take it apart?
kloan
Post by kloan » Sun Jul 08, 2007 1:46 pm
I'm trying to get my '68 Dream going.. the throttle handle doesn't turn very far, maybe 1/8 turn if that, it feels like it's disconnected from the throttle cable and is stuck on something.. how do I go about taking it apart?
Dogsbd
Post by Dogsbd » Sun Jul 08, 2007 2:01 pm
Remove the two phillips head screws from the switch housing, pull the two switch housing halves apart and the throttle tube/grip should come off when you twist it clockwise.
joeweir1
Post by joeweir1 » Sun Jul 08, 2007 9:03 pm
Maybe your cable is seized or the Carb slide is binding also.Make sure the adjuster section where the cable runs thru the frame is together properly also.Things to check if the grip is not the problem.Joe
kloan
Post by kloan » Mon Jul 09, 2007 12:00 pm
Cool, thanks guys.. seems simple enough.
I know it's definitely not the cable or carb, because I checked both when I pulled the carb.. I was gonna clean it, but it looked clean as is.
I'm gonna check out the throttle tonight after work and see what's up.
Post by LOUD MOUSE » Mon Jul 09, 2007 3:22 pm
Consider loosening the 2 screws and moveing the throttle to the end of the bar and check then. ............lm
kloan wrote:Cool, thanks guys.. seems simple enough.
kloan
Post by kloan » Mon Jul 16, 2007 9:52 pm
Got it, thanks.. :)
It just wasn't aligned properly in the slotted groove... it turns now, but doesn't recoil at all.. I have to wind it back.
I'm going to try lubing the throttle cable and throttle handle and see if that helps. The spring action on the carb seems fine.
