main stand spring hook
3BeanCrispy
Post by 3BeanCrispy » Tue Apr 29, 2008 6:16 pm
is the main stand spring hook supposed to be flat or rounded, in perspective to the thickness axis. sohuld it lay flat as if cutout from a piece of sheetmetal ? or as if it was cutout then bent/shaped? mine looks like a c-shaped egg cradle
Re: main stand spring hook
Post by LOUD MOUSE » Tue Apr 29, 2008 8:30 pm
Stamped from sheet steel. ................lm
3BeanCrispy wrote:is the main stand spring hook supposed to be flat or rounded, in perspective to the thickness axis. sohuld it lay flat as if cutout from a piece of sheetmetal ? or as if it was cutout then bent/shaped? mine looks like a c-shaped egg cradle
3BeanCrispy
Post by 3BeanCrispy » Thu May 01, 2008 8:25 pm
thanks ! i figured it should be flat, but wanted to double check before flattening it.
how about the rear brake rod ? i'm guessing it should be straight and not generously arced over it's length.
milwaukeephil
Post by milwaukeephil » Mon May 12, 2008 3:56 pm
Speaking of springs, I almost took an eye out on my CL350 last summer, so used this method to put the spring on with no swearing involved. Stuck one end of the spring in a vise and bent it back and forth adding pennies, then put it on the bike and pulled the pennies with a pliers...
3BeanCrispy
Post by 3BeanCrispy » Mon May 12, 2008 4:16 pm
quite innovative ! adding that one to my bag of tricks hehe
milwaukeephil
Post by milwaukeephil » Mon May 12, 2008 4:21 pm
Wish I could take credit; don't remember who told me to try it but it works great...
fallingpines305
Post by fallingpines305 » Mon May 12, 2008 6:30 pm
Not many tools cost 43 cents these days, you did well.
