Valve Ajustment ca77 Help No LT or LF mark
I was reading my manual for adjusting the valves for my ca77 dream. the manual refers to the "t" ( top dead center) "f" firing and LTand LF. I dont see a Lt or Lf mark. can someone help me with this. Im getting some tapping on the right side. Not sure if its the valves for not.
Re: Valve Ajustment ca77 Help No LT or LF mark
Your DREAM has only one set of points so adjust the right side valves at "T" and points at "F" then turn the crank 360 degrees to "T" and adjust the left side valves. ...........lm
nicoderm wrote:I was reading my manual for adjusting the valves for my ca77 dream. the manual refers to the "t" ( top dead center) "f" firing and LTand LF. I dont see a Lt or Lf mark. can someone help me with this. Im getting some tapping on the right side. Not sure if its the valves for not.
RIDE IT DON'T HIDE IT!
I use a 12 volt bulb with 1 foot of wire and alligator clips batt. to ground. ..................lm
nicoderm wrote:wow thanks for the replay. this is going to be the easiest valve adjustment i've ever done.
i have another question about the timing. can i use a standard timing light? i dont need a dynamic automotive timing light with advance do i?
