Piston Ring Order
Spargett
Piston Ring Order
Post by Spargett » Fri Apr 24, 2009 5:00 am
I was curious as to the order of piston rings. I found this photo below, but I just wanted to check with you guys to make sure that it's correct. Just because someone put a picture of it on the internet, doesn't always mean it's right ; )
The bottom ring is obvious, but the top two on mine were indiscernibly different. New set looks just like what's in the photo. Thanks in advance.
P.S. I tried to search the forums in advance, I couldn't find anything.
Goodysnap
Post by Goodysnap » Fri Apr 24, 2009 5:25 am
Bills Manual says shiny silver ring on top . Dull dark ring middle. I would say your picture is correct.
64' CB77
65' CB160
Re: Piston Ring Order
Post by LOUD MOUSE » Fri Apr 24, 2009 8:25 am
LOCATIONS ARE CORRECT. BE SURE NUMBERS ARE UP. ...........lm
Spargett wrote:I was curious as to the order of piston rings. I found this photo below, but I just wanted to check with you guys to make sure that it's correct. Just because someone put a picture of it on the internet, doesn't always mean it's right ; )
RIDE IT DON'T HIDE IT!
Spargett
Post by Spargett » Fri Apr 24, 2009 6:09 pm
Thanks for the info guys. LM, not sure what you mean by the "numbers up".
LOUD MOUSE wrote:LOCATIONS ARE CORRECT. BE SURE NUMBERS ARE UP. ...........lm
Post by LOUD MOUSE » Sat Apr 25, 2009 12:12 am
YOU WILL SEE NUMBERS ON THE RIGHT SIDE OF THE OPEN END IF YOU HAVE THE RING "TOP UP". ..........lm
Spargett wrote:Thanks for the info guys. LM, not sure what you mean by the "numbers up".
Post by davomoto » Sat Apr 25, 2009 10:55 am
Also, be sure to put the end gaps 120 degrees apart.
Spargett
Post by Spargett » Mon Apr 27, 2009 3:27 am
It appears my rings don't have any numbers on them whatsoever. They're NOS honda rings too. Oh well.
LOUD MOUSE wrote:YOU WILL SEE NUMBERS ON THE RIGHT SIDE OF THE OPEN END IF YOU HAVE THE RING "TOP UP". ..........lm
Davo, thanks, saw reference to that in Bill Silver's manual. Always appreciate the reminders.
davomoto wrote:Also, be sure to put the end gaps 120 degrees apart.
