so i have just got my swingarm powdercoated and pressed in the shock bushings and some custom machined oil lite bronze swingarm bushings. i have a few questions 1. how easy should the collars sit in the bushings ( should they press in and not spin freely? once inside the bushings should they spin freely by turning them by hand? or should they be snug and barely turn within the bushings?) also should the collars be just a tad bit longer than the bushings so that the swingarm pivot bolt tightens against the collars rather than the bushings? if so can i add washers so that the swingarm then tightens against the collar instead of the bushings?
thanks for any advice.
-cheers and happy 4th!
deez
swingarm bushing and collar questions?????
Re: swingarm bushing and collar questions?????
Swing arm for what?. ......lm
deez wrote:so i have just got my swingarm powdercoated and pressed in the shock bushings and some custom machined oil lite bronze swingarm bushings. i have a few questions 1. how easy should the collars sit in the bushings ( should they press in and not spin freely? once inside the bushings should they spin freely by turning them by hand? or should they be snug and barely turn within the bushings?) also should the collars be just a tad bit longer than the bushings so that the swingarm pivot bolt tightens against the collars rather than the bushings? if so can i add washers so that the swingarm then tightens against the collar instead of the bushings?
deez
