front forks bottoming out?
deez
Post by deez » Tue Sep 08, 2009 9:05 pm
so my front forks are bottoming out really easily as i ride. i have type 1 forks
with belray 10w fork oil and i put around 7.5oz in. im only 150lbs? did i rebuild these things
completely wrong? do the springs go in only one way? any advice would be appreciated.
-cheers
-deez
Post by davomoto » Tue Sep 08, 2009 9:09 pm
Deez, forks are soft! Try adding a 1/2 inch spacer under spring, and 15w oil. This will stiffen forks, and slow down rebound so they won't pogo. If you just go with heavier oil, the forks tend to pack up, they can't rebound fully before hitting the next bump, and make for a really harsh ride.
deez
Post by deez » Tue Sep 08, 2009 9:16 pm
yo davo,
do yours bottom out on your cafe? i mean these things cant be right, they bottom out way too easy!
what would you suggest i use for a spacer? also does anyone make better fork springs for this set up?
-cheers
and thanks again davo
Post by davomoto » Tue Sep 08, 2009 9:27 pm
Deez, yes they do bottom out! Try using an aluminum spacer that fits in tubes. I think progressive used to make them back in the day, but you'd be hard pressed to find them now.
jensen
Post by jensen » Wed Sep 09, 2009 2:08 am
Yes,
I'm busy with this, but it will take time to sort out.
see the link superhawk meets triton
http://www.honda305.com/forums/viewtopic.php?t=1479
as said, I changed the suspension of my Honda CB400F with very good results,
The person who has to make these springs is working as a technician in this area.
He will do this in his spare time, so I have to be patience.
If you like, I will keep you informed,
