So I'm sifting thru some engines, looking for a good one to rebuild for my 62 CB72. I find one with engine # CB72E- 930 not 5 digits, not 6, just three digits. the crosshatching in the # area is intact and looks very original. I have piles of these engines, 305's & some 250's but have never seen a 3 digit serial # ? anybody else? I did find a 62 250 engine here but the crank bearings have been pounding the case so I'm thinking I'll go with this #930 case as it looks very good.
Thanks
Randy
CB72 Engine serial #'s
- Contact:
Nice found, and seems to could be a 59 engine, the number starts with a 9.
Is the cylinder head (top) cover original to the engine ? Does it have the holes for the condenser ? (it should be attached like a dream, on the cylinder head cover).
Does it future a 360 degree crank ?, or a 180 degree crank ?
yes, replacement cases were available. AFAIK originally they were die cast, the same as production items and later on they were sand cast and much thicker and stronger.
Yamaha supplied crank cases with no numbers in that crucial number pad area. Honda cast cases were also blank but I can't speak for the die cast cases. Probably teh same.
