Hi all....1966 Dream here. Just got it. 5,361 miles...Garage find.
It has its kinks....One in particular is that it just started reving on me. The throttle has no effect on it. eventually it goes back to normal..... .anyone have advice?
You are all great on these forums!
Electrical probs. too I'll ask about later,
New Dream owner......Reving engine...
Sounds like a stuck throttle, throttle cable, or carburetor slide-easy to check, with the engine not running, pull the air cleaner and look/feel for the carburetor slide to move easily up and down in sync with the throttle. Old gas gets gummy and can make the slide sticky, and old cables need to be lubed to work again- and make sure the cable isn't kinked or poorly routed causing a sharp turn in the cable.
Rick
Rick
