CA-CB gears interchangeable?
OldStan
Post by OldStan » Fri Feb 18, 2011 3:29 pm
I need to change a couple of gears on my CA, the 23t and 27t (slider) on the main shaft. From the parts books the CA and CB are different part numbers for the same gears with the same number of teeth. Same goes with the CL. (xing gears would put them in the same position.) Is there a difference or are they interchangeable? If they are the used parts would be easier to find.
63 CA78
