Post
by lewarcher » Tue May 24, 2011 11:31 pm
Ok, I am looking into putting a CB77 engien in a CA77 frame. Or if the bottom ends are the same between the two, just swap the top ends.
Anyone know if this is possible? I know that there most likely be a problem with the two CB77 carbs clearing the frame (I would make carb manifolds and hope they work) and would have to use the CA77 top of the cylinder casing so I could bolt it up to the frame.
I would have to swap out the coils, points, condensers...any other electronics?
And someone suggested swapping out the sprockets??
Has this been done before? Could it be done?
