cl77 clutch to hard to squeeze
CFL
Post by CFL » Thu Feb 21, 2013 3:04 pm
Rebuilt cl77 clutch. All new discs and cable. It takes a super grip to squeeze the lever to work the clutch. Can the springs be too stiff for some reason. I have double checked the assembly and the ball to rod connection. Any ideas would be great. Sincerely, CFL
mike in idaho
Post by mike in idaho » Thu Feb 21, 2013 3:36 pm
Did you make the clutch lifter adjustment with the cable backed off all the way?
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
CFL
Post by CFL » Fri Feb 22, 2013 9:38 am
I set the cable and lever to the book. I will try different settings. Thank you very much, CFL
mike in idaho
Post by mike in idaho » Sat Feb 23, 2013 3:52 pm
Clutch release pushrod is straight(no binding) and the bearing ball is in place? Pull the side cover off and look at lower end of the cable. With the clutch lever pulled in to the grip the angle between the end of the cable and the release arm should not be past 90° for the easiest pull.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
CFL
Clutch cable
Post by CFL » Sun Feb 24, 2013 8:52 am
Thank you very much for your expertize. I'll give it a try. I had a 305 back in the 60's and I remember that the clutch was always a little hard to squeeze back then. Not like the Nighthawk 750 that I have now. I just gave away my age, I'm an old baby boomer. Thanks again, Sincerely, CFL
Post by davomoto » Mon Feb 25, 2013 9:51 am
Proper cable routing is essential as well. Any tight radiuses will make it really hard to pull.
Davo
CFL
clutch squeeze
Post by CFL » Mon Feb 25, 2013 11:22 am
Thank you for the tip, I'll pull out the cable so it is almost straight and give that a try. Many thanks, CFL
