Float removal
noeyes
Float removal
Post by noeyes » Sun May 18, 2014 1:11 pm
Hey Guys. New to the forum. Picked up a '64 CA77 last week.
First off let me say I know nothing about Carbs. Usually if I study it long enough tho, I can kinda grasp it.
One side of the float in my carb looks to be bent down and not level. Got a new float ordered, but not sure how to get the old one out. Is the pin holding it in threaded or is it just pressed in. How do I get it out?
Wanted to ask here before I go banging on it.
Thanks,
Mark
Post by G-Man » Sun May 18, 2014 1:31 pm
Mark
the pin is a light push fit but corrosion will make it tighter. support the opposite post and try with a very thin punch to tap it gently. Not too hard as the support posts are easily broken.
noeyes
Post by noeyes » Sun May 18, 2014 3:32 pm
Thanks G!
I'll give a try.
bbap
Post by bbap » Sun May 18, 2014 5:40 pm
Mark, G-man is quite accurate. If you do not have a micro-punch, use a small brad nail with the point blunted. Slight tap and she's out, but support the opposite side if any more than a slight tap. Steve
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
noeyes
Post by noeyes » Sun May 18, 2014 7:38 pm
Thanks! I used a screwdriver from a micro set and just barely tapped it with a small hammer. Came right out.
