Detecting oil pressure...
R100
Post by R100 » Tue Oct 07, 2014 6:37 pm
Is there a way to determine if oil is being pumped?
Perhaps by removing the valve inspection caps and running the starter motor?
conbs
Oil Pump
Post by conbs » Fri Oct 10, 2014 10:00 am
Search this site. I think I have read at least one post that suggested loosening the outside acorn nuts on top of the cylinder.
You may want to just pull the oil pump and inspect the insides. I got a refurbished one from LM for a very reasonable price.
R100
Re: Oil Pump
Post by R100 » Fri Oct 10, 2014 10:51 am
conbs wrote:Search this site. I think I have read at least one post that suggested loosening the outside acorn nuts on top of the cylinder.
Found it. Thanks.
Front outboard acorn nuts.
garncarz
Post by garncarz » Fri Oct 17, 2014 12:31 pm
1. Check to see if you have oil in the crankcase.
2. Start it up.
3. If you see oil leaking from the cylinder head acorns or the head gasket, you have pressure.
