assembling transmission question. Is this noise normal?
big-b
Post by big-b » Sat Feb 21, 2015 7:54 pm
So the new offset cotter are in (much better). Gears spin freely and engage properly but, when i assemble the case halves (just test fitting) and install the shift stopper hardware i get a clicking noise when i spin the shafts. Its not the clicking from the k/s paul, it's when i rotate them the other way. If i rotate the k/s shaft about 1/8 turn and hold it in that position everything spins freely with no noise. What's going on here? I was thinking that when the k/s assembly is put together maybe the return spring applys rotational pressure to the K/s shaft so this isn't really an issue? I could be wrong though. I thought i remember reading a post on the 305 forum but i couldnt find it again.
Brian
mike in idaho
Post by mike in idaho » Sat Feb 21, 2015 8:28 pm
Yes, that's normal, the kickstarter pawl is retracted by the kick starter spring just like you said.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
