CB77 jumps into gear when pushing
will305
Post by will305 » Fri May 29, 2015 11:14 am
Hi Everyone,
Well I took delivery of my 65 CB77 today and thought it would be more than a minute to start the list of things needing attention - wrong! Pushing the bike into my garage, it seems to jump into gear from neutral. Just backing it up releases it for a few feet.
Before it catches, there is a clicking noise in the gear box and there doesn't appear to be any clutch to speak of.
Of course the seller didn't share any of this part with me!
Any ideas?
Will
Houston, TX
65 CB77
Waveblaster
Post by Waveblaster » Fri May 29, 2015 11:39 am
you might need to provide a bit more background information to folks can help diagnose
will305
New Arrival Tranny Issue
Post by will305 » Fri May 29, 2015 12:07 pm
Waveblaster wrote:you might need to provide a bit more background information to folks can help diagnose
Thanks for the reply. Here is as much background as I have:
The bike hasn't been run in 10 years so all of the cables are in bad shape and need to be replaced. Since I can't start the bike yet, I was hoping someone could suggest why the bike rolls freely for a few feet and then jumps into gear. Could it be that the gears are so worn, it won't stay in neutral?
Again, once in gear, the clutch doesn't help as I believe the cable is so far out or the clutch is just bad.
It also does this sitting on the stand and the clicking sounds like it's coming from the drive chain side before it jumps into gear. Backing the wheel releases it back into neutral, as does using the shifter.
Any help or first steps is much appreciated.
Will
Post by G-Man » Fri May 29, 2015 12:13 pm
Will
It sounds to me like you aren't actually in neutral. Maybe just between two other gears. Try and find first gear, then ease up into neutral from there.
Put the bike on the stand and count through all the gears.
Post by LOUD MOUSE » Fri May 29, 2015 9:22 pm
Do you have the kick starter lever installed correctly?
Does it move as you roll the bike?. ..............lm
G-Man wrote:Will
will305
Post by will305 » Sat May 30, 2015 7:47 am
LOUD MOUSE wrote:Do you have the kick starter lever installed correctly?
LM,
Actually, the guy hasn't sent me the kickstart lever yet, so it's not installed. In watching closely, the lever shaft doesn't appear to move as I spin the wheel on the stand.
I know that with the limited info I'm able to provide, this is really tough for you guys to diagnose. Was hoping it might be a common symptom you've seen before. I am going to proceed with all the other steps I need to do in order to get it running (oil, carbs, new battery, etc), and then see if this is still an issue.
LM, I see you're in Kerrville….maybe I will have a chance to meet you if you attend the Harvest Classic in Luchenbach in October…I plan to go this year.
Thanks for the help on this.
Will
bamacl
Post by bamacl » Sat May 30, 2015 9:01 am
The kick starter return spring keeps tension on the shaft to disengage the starter pawl in the normal position. If the kick starter is missing then the pawl might not be disengaged.
