                    Speedometer drive oil seal
Has anyone replaced the oil seal on the speedo drive? I have found 2 part numbers: 90752-250-000 and 90752-253-000. The "250" for early frame numbers I think. Neither of these fits my Dream. I have 3, all are the same and all are around frame numbers CA78-1013261. The speedo drive is the same for all 3. The oil seal has a number embossed on it: TC 34 48 6.5 Y1. Any ideas?
Re: Speedometer drive oil seal
34 48 6.5
Order a seal with that number. ..............lm
305martin wrote:Has anyone replaced the oil seal on the speedo drive? I have found 2 part numbers: 90752-250-000 and 90752-253-000. The "250" for early frame numbers I think. Neither of these fits my Dream. I have 3, all are the same and all are around frame numbers CA78-1013261. The speedo drive is the same for all 3. The oil seal has a number embossed on it: TC 34 48 6.5 Y1. Any ideas?
Oil seal,
If it's a 'standard' size seal you should get one from a bearing specialist supplier, much cheaper than a Honda part too. Just quote the sizes or search on line, an oil seal is an oil seal, well mostly anyway!
						Re: Oil seal,
DJM
Indeed! Just to help our friend a bit more, those numbers - in millimetres - are Inside diameter, outside diameter and thickness.
DJM wrote:If it's a 'standard' size seal you should get one from a bearing specialist supplier, much cheaper than a Honda part too. Just quote the sizes or search on line, an oil seal is an oil seal, well mostly anyway!
'60 C77 '60 C72 '62 C72 Dream  '63 CL72
