Stator on 66' CL77
moondoggers
Stator on 66' CL77
Post by moondoggers » Tue Jul 28, 2020 5:04 pm
Upon routine tune-up & inspection I found the stator winding's to be loose, so I am looking for a viable stator to purchase.
Thank you.
DJM
Re: Stator on 66' CL77
Post by DJM » Wed Jul 29, 2020 3:05 am
If the stator is still working OK you should be able to fix it. The coils are basically held in place by two thin steel tabs bent outwards over the coils,
Try tapping these back into place Gently to see if this helps, You could also fix them in place using a thin epoxy resin mix poured into the space around the coils, not to much and perhaps only one or two coils at a time to let gravity help the stuff get where t's needed.
Why not give it a try as you don't have much to loose.
moondoggers
Post by moondoggers » Thu Jul 30, 2020 1:36 pm
Yes, I will give it a go . Like you say I have nothing to lose.
moondoggers
Post by moondoggers » Sun Aug 02, 2020 1:02 pm
I don't see the tabs I should bend back, can you show me a picture ?
Post by LOUD MOUSE » Mon Aug 03, 2020 4:21 pm
The winding is a coil. In the middle is a steel part with tabs on the inside and outside of the steel. ..............lm
