CA77 clutch basket
gideon
CA77 clutch basket
Post by gideon » Wed Jul 27, 2011 12:08 pm
I want to open up the clutch basket of this '62 dream and clean the clutch plates with WD40 because they are dirty. I noticed that the 4 hex bolts that hold down the springs were not tightned all the way , but were 4 1/2 turns out from the bottom. With my 68 CD175, the Clymer book says to tighten them down securely. Is there a difference with the 305 . Seems logical to tighten them up all the way . Thanks, Jeff
Post by davomoto » Wed Jul 27, 2011 3:00 pm
Should be tightened down.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
gideon
tightening up the clutch basket
Post by gideon » Wed Jul 27, 2011 3:07 pm
Thanks! That's what I thought . I wonder how they got so loose ? - Jeff
Post by davomoto » Wed Jul 27, 2011 3:13 pm
Methinks someone forgot to tighten them.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
OldStan
Post by OldStan » Wed Jul 27, 2011 3:31 pm
When I took mine apart the bolts were also loose. There was a mixed stack of plates of different thickness making total stack too much. I think they were left loose so the clutch could be pulled (it was still hard.) If you have the all fiber plates you might want to check for that.
63 CA78
gideon
the clutch
Post by gideon » Wed Jul 27, 2011 8:05 pm
Wow, this gets deep, but it's OK; I'm just looking at spending some bucks for parts on e-bay which I'm not too crazy about for some reason. hA! - Jeff
