question about clutch cables
Two photos attached, first is old clutch cable. When assembled the clutch thread and adjuster rests at 90 degrees or there abouts.
I bought a new cable from Charlies Place that was specifically for low bars. When this new cable is assembled the thread and adjuster rests at 115 degrees or there abouts.
You can see the difference in the amount of cable between the thread and the joint at the top of the crankcase...maybe its about an inch or so. What results with the new cable is that the cable will NOT spring back after it is depressed, I am guessing because the spring is in too much tension to begin with.
The new cable is as adjusted both at the lever and the crankcase to provide the most amount of cable (i.e. the least amount of tension) but it seems like I still need another inch or so.
Is there a way of adjusting this at all, or is the cable just too short?
And if so, is there any way of lengthening?
Thanks for the help!
old cable by Dr125, on Flickr
new cable by Dr125, on Flickr
