Trick with pulling the rotor off?
Trick with pulling the rotor off?Is there a trick to pulling the rotor (from the charging system) off? I see I need 07933-2160000, is there any alternatives to using that tool?
re:pulling rotorYou can use a 16 mm. bolt with a 1.5 mm. pitch. Might be hard to find. I could not find any bolts on my CB 77 that will do it. Needs to be about 2" long or so.
Mike Mullins "a free motorcycle is a bottomless hole intended solely for money"
66 CB 77 76 BMW R75/6 99 GL 1500 trike 75 & 79 XS 650's
Yeah I tried just for the hell of it. I went to Tacoma Screws today and they weren't open so I'll hit them on monday and get the bolt.
The rotor isn't a terribly big concern at the moment. I'm having trouble removing a stuck bolt. My easy out broke on it and I can't get the broken bit out to drill the bolt.
toolsGo to Harbour freight and pick up a chain break tool. Large thread of the tool will remove that rotor. Yeah I know, most of us don't like to support them but what the hell, you get two tools in one. Rusty
