Motor Paint for CB and CL 77 restore?
nkarshna
Post by nkarshna » Mon Aug 14, 2006 11:35 pm
Does anyone know for sure if the Krylon Dull Aluminum paint (per Bill Silvers Book) will hold up to the heat of the engine? and If so would it be a accurate restore if I used it on the bottom end of the engine not just the case covers? Thanks
Re: Motor Paint for CB and CL 77 restore?
Post by LOUD MOUSE » Wed Aug 16, 2006 8:38 am
It holds up with the heat and can be touched up when required.
The head/cylinders/and cases were not painted with anything. ...........lm
nkarshna wrote:Does anyone know for sure if the Krylon Dull Aluminum paint (per Bill Silvers Book) will hold up to the heat of the engine? and If so would it be a accurate restore if I used it on the bottom end of the engine not just the case covers? Thanks
nkarshna
Post by nkarshna » Wed Aug 16, 2006 10:13 am
Thanks for the advise. So the whole engine wasn't painted with anything? What would you use?
Post by LOUD MOUSE » Wed Aug 16, 2006 10:26 am
I do use the Krylon Dull Aluminum on the side cases but nothing on the rrest of the engine. .........lm[
quote="nkarshna"]Thanks for the advise. So the whole engine wasn't painted with anything? What would you use?[/quote]
ChickenHawk
engine color
Post by ChickenHawk » Tue Oct 23, 2007 3:19 pm
so if the engine wasn't painted originaly, how do you get the cases to look really nice?
Re: engine color
Post by LOUD MOUSE » Tue Oct 23, 2007 3:22 pm
The engines I rebuild have sand cast parts which can be blasted with sharp glass followed with round glass. ......................lm
ChickenHawk wrote:so if the engine wasn't painted originaly, how do you get the cases to look really nice?
Gun
Re: engine color
Post by Gun » Tue Oct 30, 2007 10:33 am
LOUD MOUSE wrote:The engines I rebuild have sand cast parts which can be blasted with sharp glass followed with round glass. ......................lm
If someone didn't have the tools or access to such things, what would your recommend for cosmetic upgrade on the engine?
sandblast or bust?
