Fixing Cracked Side Panel
akpasta
Post by akpasta » Sat May 05, 2012 7:44 pm
Left side panel cracked from vibration. I'm sure this has happened to lots of you. What would you say is the best way to fix it? It feels like it's maybe aluminum. Probably can't JB Weld it, seems like the vibration would snap it apart. What have you guys done or what would you suggest?
thanks.
Re: Fixing Cracked Side Panel
Post by LOUD MOUSE » Sat May 05, 2012 7:53 pm
Ya should find it is steel with a magnet.
I'd buy another one. ...........lm
akpasta wrote:Left side panel cracked from vibration. I'm sure this has happened to lots of you. What would you say is the best way to fix it? It feels like it's maybe aluminum. Probably can't JB Weld it, seems like the vibration would snap it apart. What have you guys done or what would you suggest?
thanks.
Post by G-Man » Sun May 06, 2012 2:16 am
Easy welding job.....
Find a local guy with Oxy-Acetylene or TiG equipment. Make friends with him and buy him a
beer......
10 minutes with a file / dremel / wet or dry paper and you're done.
akpasta
Post by akpasta » Sun May 06, 2012 2:40 pm
Cool. Glad to know it is possible. Can this sort of job be done without fucking up the paint a whole lot or should I expect to have to sand down and re-paint the whole thing?
Post by G-Man » Sun May 06, 2012 3:52 pm
You can expect the paint to be burned away y for a couple of inches around the repair. Bargain on sanding and repainting the complete piece.
If you are squeamish about that you are probably better off going the LM route.... :-)
akpasta
Post by akpasta » Mon May 07, 2012 11:42 am
I don't really care about the paint being messed up. thanks.
OldStan
Post by OldStan » Mon May 07, 2012 1:42 pm
You might also get some warpage from the welding. You'll get less with the TIG welding.
63 CA78
