Rear Wheel Bearings
68Cb77
Rear Wheel Bearings
Post by 68Cb77 » Thu Mar 20, 2008 6:21 pm
I've got 2 new bearings ready to go in the hub. One side is sealed, and the other side has the balls more exposed. When I took the old ones out, the sealed side was on the outside. Is that right? Thanks
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
ggray
seals
Post by ggray » Thu Mar 20, 2008 6:48 pm
Seals go to the outside.
Gary
'65 CL77 Owner
68Cb77
Post by 68Cb77 » Thu Mar 20, 2008 8:02 pm
Thanks Gary
82 Honda XR200R
70 Honda CB750 K0
ggray
Seals
Post by ggray » Fri Mar 21, 2008 8:48 am
You're welcome. Just make sure you pack the bearings well and grease goes in the void between the inner and outer bearing..........Where the bearing spacer is.
Gary
'65 CL77 Owner
Re: Seals
Post by LOUD MOUSE » Fri Mar 21, 2008 11:11 am
Grease in the void/spacer???????????. .........lm
ggray wrote:You're welcome. Just make sure you pack the bearings well and grease goes in the void between the inner and outer bearing..........Where the bearing spacer is.
Gary
68Cb77
Post by 68Cb77 » Sat Mar 22, 2008 10:18 am
Don't need to fill that with grease?
82 Honda XR200R
70 Honda CB750 K0
Post by LOUD MOUSE » Sat Mar 22, 2008 4:41 pm
Not even. The axle goes through it but doesn't touch it. ...............lm
68Cb77 wrote:Don't need to fill that with grease?
