should I be hearing my valves?
Post by LOUD MOUSE » Sun Aug 03, 2008 11:19 am
Sometimes the gasket comes off OK. ..........lm
allthumbs wrote:hardly a detectable movement in the shaft. can't see it move I can just barley feel it. if I remove the whole assembly I'll have to clean it up and replace the gasket no?
RIDE IT DON'T HIDE IT!
allthumbs
Post by allthumbs » Sun Aug 03, 2008 1:02 pm
this all seems fine, I guess I'll just plan on the rivet weld a little later.
still the damn popping on the left side. I give up on perfection
Post by LOUD MOUSE » Sun Aug 03, 2008 6:18 pm
Adjust carb air/slow speed screw. ......................lm
allthumbs wrote:this all seems fine, I guess I'll just plan on the rivet weld a little later.
allthumbs
Post by allthumbs » Sun Aug 03, 2008 7:31 pm
every day man, every day
allthumbs
I screwed the air screw out more than 3 turns.....
Post by allthumbs » Sun Aug 17, 2008 5:46 pm
and the popping stopped. awesome. adjusted the idle and all was smooth. after the motor heated up a bit was back to popping but not as bad...carbs are really almost synced well.
Maybe an indication that I need to put new kits in the carbs?
anyway, I think I can get it just about right next try.
so thanks for that LM
allthumbs
Post by allthumbs » Thu Oct 02, 2008 4:43 pm
I have a question to someone who has done proper tappet adjustments. would you mind saying what the proper procedure is?
On a cold motor I get the right side at tdc, and adjust. then I rotate to tdc on the left, one full revolution plus a half? you see. when at tdc (compression stroke) on the right, and after the adjustment, the valves sink further into the motor half way between left tdc. If I understand Clymers correctly is says at tdc the valves should be all the way in.
Where am I wrong here, I've done it 3 times...no good.
pretty confused between the two books, Silvers and the sometimes conflicting clymers
Thx much
Post by LOUD MOUSE » Thu Oct 02, 2008 4:53 pm
On the left in the yellow band you will see the FAQ list. Look at the How I Tune My Engine and you will find you are not adjusting the cams correctly. .............lm
allthumbs wrote:I have a question to someone who has done proper tappet adjustments. would you mind saying what the proper procedure is?
Thx much
