cb72 oil filter seized up overheated and melted
here are a few pic's of the oil filter from my 64 cb72 it looks like it froze on it's shaft at somepoint in it's life and got very hot anyone see this before? what caused it by the way the washer was on the outside stuck with melted aluminum on it. also the sprocket is able to turn on the housing.
added info
there was oil in the bike and oil did come out of the filter when i removed it
James
James
Re: added info
I'd say the washer was left off the shaft on the locater pin end and the cap and large cover started to eat each other and the heat was transmitted thriugh the entire part.
Take a look at the inside of the cover. ................lm
thumper2146 wrote:there was oil in the bike and oil did come out of the filter when i removed it
James
RIDE IT DON'T HIDE IT!
washer
the locater pin was in place and i had to pry the washer off the end:(
Re: washer
Was the washer the correct one?
Was it scared like the cap end?. .........lm
thumper2146 wrote:the locater pin was in place and i had to pry the washer off the end:(
washer2
no but it did have allot of melted aluminum on it I have no idea if it was the correct one but i will take a pic and post it later on today
thanks for your time.
james
james
