Sloppy gear shit linkages
leonvjames
Post by leonvjames » Fri Feb 26, 2010 3:27 am
Years ago I had a similar problem on the lever that clamps to the shaft so I cut the top off the lever and sawed through the remaining bit so it was split all the way through and it always clamps up tight. Also used a longer bolt with a nut on it to make sure. It still works fine.
Leon. long time owner and rider.
Post by G-Man » Fri Feb 26, 2010 8:15 am
Toasty
It helps if you put where you're from in your profile. Those threads are M8. I have a drawer full of M8 spherical rod-end bearings. Sadly no left-hand ones....
I'm going to machine up a linkage set out of stainless for my CB77. That way I can control all of the clearances.
