Brake Light Switch
Sascha
Brake Light Switch
Post by Sascha » Fri Dec 10, 2010 10:05 am
Hey Guys,
So I came to a funny realization last night as it relates to the brake light...
So the brake 'running light' is actually when the brake switch is pulled down and the lever activates the 'braking" light when the switch pin moves farther upwards. Is this correct? I realize I have it backwards.
-Sashca
brewsky
Post by brewsky » Fri Dec 10, 2010 8:18 pm
The running light and brake light are 2 separate filaments in the same bulb.
The running light stays on all the time the light system is energized
The brake light only comes on when the switch is pulled down by the brake pedal.
Sascha
Post by Sascha » Mon Dec 13, 2010 9:16 am
Hey guys,
Im having a serious issue with this... I believe its becuase I dont have the correct cable/spring that runs from the lever to the brake switch. Anyone have a source on this?
-Sascha
Post by davomoto » Mon Dec 13, 2010 9:35 am
Sasha, most hardware stores have a couple drawers of assorted springs. Measure te distance you need to span, and go have a look at what they offer.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Eljeef
Post by Eljeef » Mon Dec 13, 2010 9:44 am
Sascha, I bought that exact spring from Ohio Cycle. If it is the spring you need then it is part#35357-253-000 ($10) or 35357-271-000 ($6.50) depending on your frame vin. If it is the stop switch rod then it is part# 35355-259-000 ($5). I may have the dollar figures with the wrong numbers but they are the correct amounts anyway. Call Nick. Regards, Jeff H.
1964-C77 305 Dream
2002 BMW R1150GS
Sascha
Post by Sascha » Mon Dec 13, 2010 12:27 pm
Guys,
The issue is that whenever I use my foot on the lever, it moves the pin upwards, not downwards... !?
-Sascha
brewsky
Post by brewsky » Mon Dec 13, 2010 1:58 pm
Sascha wrote:Guys,
-Sascha
Not sure how that could happen.
Look at the Main Stand, Step bar diagram in the parts book (pg 68) to see how it should be aligned.
The spring is connected to the rear brake spindle, and the stop switch arm. The switch is connected to the stop switch arm with the stop switch rod.
The rear brake spindle should be aligned at 12:00 position.
