CL72 Carb question....
Psierako
Post by Psierako » Mon Jun 06, 2011 8:39 am
I'm restoring an CL72 250 and only have the left hand carb, no idea where the other went to... I need some help or info:
first off, can a 305 carb be used on a 250 if adjusted correctly?
Second, if not, does anyone know of anywhere good to purchase a right hand carb?
It is a Keihin pw22 and has the CL72A enscripted on it. ebay only has a limited amount of carbs and i really have a hard time trusting the quality of the product on there..
any help would be much appreciated!!! Thanks for your time!!
Dana01
Post by Dana01 » Mon Jun 06, 2011 10:55 am
Good day and welcome to the forum. Please add your location to your profile.
Your question will get answered and you'll find your carb.
Dana
1966/7 CB-77 Red of course
Psierako
Post by Psierako » Mon Jun 06, 2011 12:17 pm
thanks! location updated!!
Post by G-Man » Sat Jun 11, 2011 2:52 am
Hi
Welcome to the forum. The CL72 carb is 22mm and the 305 (CL77) is 26mm so will not work properly. You need to look out for a CL72 or, perhaps, a CB72 carb.
Keep looking on eBay and someone here may have on for you.
Post by G-Man » Sat Jun 11, 2011 2:55 am
These are from one of the guys on this forum. They may work for you....
http://cgi.ebay.com/ebaymotors/1962-Hon ... 500wt_1136
teazer
Post by teazer » Sat Jun 11, 2011 5:15 pm
Nice find G-Man.
the other answer is that the 26mm CL/CB77 carbs can be used as a pair but they are a little large for a stock motor. That used to be a common hop up trick back in the day and it's not hard to fit them, but you should use matching insulating blocks which are different on the 305s. In a pinch you could dremmel yours out to suit.
Jetting might be off, but we use those carbs on a CB175 race bike (180cc) and they work fine but we had to make a few changes to the needles and needle jet and main jets
