Clutch problems - tried everything (I know of)
Jlovvorn
Post by Jlovvorn » Thu Jan 12, 2012 7:32 pm
The large screw?
I turned it to line up with the mark, as per the clutch adjust directions (assuming I got them right).
Once on the bike, the screw only rotates from 12 to 4, with the mark being about halfway.
Is that the proper travel?
Something tells me something was put in wrong with that screw or the barrel on the inside.
It's the only thing left, unless the PO put in one too many clutch plates or something.
Again, many thanks.
Post by LOUD MOUSE » Thu Jan 12, 2012 8:01 pm
Turn the adjuster clockwise until it stops.
Turn back apx. 1/8 inch.
Tighten the bolt and ya should/may have a clutch. .....lm
Jlovvorn wrote:The large screw?
Again, many thanks.
Jlovvorn
Post by Jlovvorn » Thu Jan 12, 2012 8:05 pm
Thanks. That's the procedure on my 160. Got bad advice off this forum.
We do adjust over.
Post by LOUD MOUSE » Thu Jan 12, 2012 8:08 pm
I neglected to say to use the cable adjusters to have lever at 1/4 inch to start the pull on the cable. .....lm
Jlovvorn wrote:Thanks. That's the procedure on my 160. Got bad advice off this forum.
We do adjust over.
Jlovvorn
Post by Jlovvorn » Thu Jan 12, 2012 8:20 pm
No joy. Still have half a clutch.
Can barely shift and bike wants to stall in gear with clutch pulled.
Only three things left:
Push rod is the wrong size
Something wrong in the basket (too many plates?)
Witchcraft
Jlovvorn
Post by Jlovvorn » Fri Jan 13, 2012 7:28 pm
Gentlemen, we have a clutch....
Just got back from first test drive.
Only took hours of free tech support on the phone from LM.
Full report to follow, but short answer is "wrong number and thickness of plates in the basket."
Now, I need to deal with the two stripped left cover bolts that are leaking oil everywhere.....
