1967 CA77 Restore
hondadreamca77
1967 CA77 Restore
Post by hondadreamca77 » Wed Sep 26, 2012 11:01 am
Two bike pics below are BEFORE any work began. Me painting is recent pic.....
Got this bike in Feb 2012. Pretty much unmolested, 5 K miles, engine locked with extensive rust on R. side where it sat under edge of shed for 32 years. Have torn down to frame, engine on bench, parts labeled. First step was sandblasting frame and all sheet metal.
Now spraying first coats of enamel and doing body work glazing. After frame will move to engine overhaul, restoring all trim, then electrical.
When I was four (1963) a teenage friend of the family gave me a ride on his 305. I followed the CA110's, Dreams, CB's, etc all through the sixties and seventies and always liked this style Honda. Along the way I have owned a pristine 750 four, a CL125, and a very nice Cub 70. I plan to keep this 305 for personal enjoyment and my goal when done is a solid bike that looks good. I keep a video link of restoration progress at http://www.youtube.com/user/305hondadream?feature=mhee
Cheers,
Steve
Bike as found
Bike as found
Last edited by hondadreamca77 on Tue Dec 04, 2012 11:32 pm, edited 9 times in total.
hondadreamca77
Update 1
Post by hondadreamca77 » Fri Oct 12, 2012 7:23 pm
Restored the handlebars today. Originally I was going to trash them but on second inspection decided to save them. I want to re use as much original parts as possible.
1) Cleaned everything and rust spots with steel wool.
2) Reworked wiring/switches/contactors
3) Buffed out perches, switches, levers with jewelers rouge. Wowzer!
4) Straightened the bars. Right handle grip was 1.5 inches higher than left. Have them within 1/32" now.
5) Cleaned and serviced original throttle cable and throttle slide... both excellent shape.
First pic below shows perches buffed and not, side by side. Next will clear coat everything and spot touch paint the small rust spots on underside. I am happy with decision to rework the bars. Will keep the aftermarket Grand Turismo grips...my 750 four had them and I like them.
Last edited by hondadreamca77 on Wed Oct 17, 2012 10:15 am, edited 1 time in total.
hondadreamca77
#2 Petcock Repair
Post by hondadreamca77 » Sat Oct 13, 2012 5:08 pm
Did the messed up petcock repair today...in and out. It was totally clogged, crudded, etc. I did use a rebuild kit. If doing over again I would just order a ebay petcock replacement. This was the biggest hassle on doing the bike.
Last edited by hondadreamca77 on Thu Jan 03, 2013 10:06 am, edited 1 time in total.
hondadreamca77
Tires and trim
Post by hondadreamca77 » Fri Oct 19, 2012 6:11 pm
Well,...I'm down to ordering all the detail goodies....found a great deal on Firestone 4 ply vintage tires and also got NOS peg rubbers, badges, NGK plug boots, latch knobs, etc. Pics below.
Last edited by hondadreamca77 on Sat Oct 20, 2012 10:26 am, edited 1 time in total.
two4one
Post by two4one » Sat Oct 20, 2012 7:10 am
Hey Steve, looking great so far. Do you use a true automotive grade clear on your polished parts or a spray bomb? Just curious. I've done both.
hondadreamca77
Clear Coat
Post by hondadreamca77 » Sat Oct 20, 2012 10:21 am
Bomb small parts... clear from quart on large parts like frames. (Rustoleum auto grade)
hondadreamca77
Update..Lights, camera, action
Post by hondadreamca77 » Fri Nov 16, 2012 4:01 pm
Lights, camera, action....got the wiring and wheels done. Everything works first try! This is starting to look like something and I'm pleased. Pics posted....
