Oil Filter Slinger cap
rneil
Post by rneil » Tue Dec 23, 2014 5:21 pm
Should the cap on the oil filter come off easily? Doing some maintenance on the bike, and can not get it to budge. I'm afraid to use a punch from the other side, as I don't want to distort the aluminum. Suggestions? Thanks!
Farm Shop
Post by Farm Shop » Tue Dec 23, 2014 6:04 pm
Yes they can be a bugger......
You can try and soak it with penetrating oil but you will still probably have to drive it apart with a punch.
Something blunt like a 1/4 drive extension works well.
The last one I did I had to hit so hard I distorted the hole and had to fix it with a reamer....
Fs
malcolmgb
Post by malcolmgb » Tue Dec 23, 2014 6:26 pm
After much soaking in penetrating oil and heat mine still didn't move, so I made a tool to pull it out, no damage was caused. I will look for it and post a picture if you are interested.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Hahnda
Post by Hahnda » Tue Dec 23, 2014 10:28 pm
When they are stubborn I have used a blind bearing puller.
Farm Shop
Post by Farm Shop » Wed Dec 24, 2014 6:01 am
+1 to the blind hole puller that would work much better than a punch....
If you don't have one an auto zone will rent them out.
rneil
Post by rneil » Fri Dec 26, 2014 1:56 pm
Thanks for all the reply's. I do have a bearing puller. I'll give that a shot.
Malcolmgb, yes, I'd be curious to see the tool you made.
Hope everyone had a merry Christmas!
rneil
Post by rneil » Fri Dec 26, 2014 8:31 pm
So an update. I used my bearing puller, and it came out no problem.
